bjt
Very Helpful Member
Guys this is no big deal. Its relatively easy to get the back panels off with the Givi rack installed - I have done it several times with no damage - its just finding the right angles and slip/flex them out. Just a bit fiddly but I certainly would not see it as any reason not to get the Givi rack.
:agree: Even if it is a little bit of trouble, the panels spend a lot more time on the Spyder than off, and the Givis are one of the best accessories you can put on the Spyder, IMHO.
Bruce
:agree:
Most of the common Spyder maintenance involves removing the front panels. Rarely have I had to remove those rear side panels. Most of the time, just taking the screws out gives enough wiggle room of the rear panels to do whatever needs to be done. Anyone who doesn't like the GIVI rack / bag system because of difficulty removing the side panels also won't like the Bushtec hitch as you have to unbolt the upper support arms to remove the Spyders underseat pan. I have removed that underseat pan 10 times more often than I've had to remove the rear side panels.
