Battery tender to USB
jbauto3
Does anybody know if they make an adapter that would plug into my usb plug & allow it to connect to my battery tender
If you're wanting to keep your battery charged by plugging your tender into the USB plug, forget it. USB is 5 volts and the battery is 12+ volts. The USB is powered through a voltage reducer chip. There is no way to reverse it. Not a workable idea.
Is this what you're looking for?
Sent on Note 5 in Taptalk
If the 12 Volt plug in your rear storage compartment is always powered, just get a cigarette adapter. If the pug is not powered all of the time, check your owner's manual and it will explain how to move the fuse for it from one spot to another. This winter will be my fourth winter using one, and it works like a charm.
This device plugs in to the tender quick connect cable attached to battery to charge USB
(same as a cigarette plug)
not the otherway around fyi.
About same as this:image.jpg
