Battery Tender Lead/Harness Location
Shurtman
Where's everyone locating their battery tender lead? I ended up drilling a hold in the frunk basin and using a rubber gromet to finish it off. Turned out ok, and provides easy access.
Depends..!
on the model and battery location. Your looks great and works for you. Many end up under the seat...well done..:2thumbs:
Mine is under the seat. However, I added a plug to extend it to a cig plug on the dash. Makes it easier to use and gives a 12v plug on the dash.
Sent from my SCH-I545 using Tapatalk
No drilling, ran it out the back and attached it right next to the left shock. Easy access.
attachment.php
I read somewhere on this forum that you can plug the tender into the cigarette lighter adapter jack in the trunk after moving a fuse to make this outlet full time live. I am new to this so I want to make sure this is correct and safe on the electrical system.
attachment.php
Same here, the F3 is so open why drill any holes?I just ran it out the back and zip tied to a solid surface also used it to plug in my phone by using a usb coverter and bringing the phone charging cable up through the steering wheel to charge phone on a ram mount.
12V
attachment.php
here's where my TRICKERLER is plugged in.....
dp
You are correct; you won't hurt the electrical system.
