Battery operated heated clothing
My Gerbing jacket works great....many hours on the battery...6+ or so and you can buy extra batteries to change out on long trips. I like mine as I also wear it while doing yard work, etc. It has four temp levels, The one or two setting is all I need. It is a great jacket without the heat....I have a wired jacket, but never wear it.
:spyder2:
the Gerbing is the same gear either way the battery is just an option to the direct plug so you can ride plugged in then get off and use battery while walking or camping
If I do change my mind and go direct to the battery do I have a problem with battery draw. My Spyder has probably has about 10 sets of optional LED add on lights plus heated grips and seat.
