wiredgeorge
I finished up installing my new anti-sway bar and metal links and was excited to see how they worked. Opened the garage door and turned the key and hit the starter. Solenoid started clicking but the bike wouldn't turn over. I have a 2010 RT and am pretty sure it is the original batter. With only 3K miles, it is likely it sat and cells got sulfated. I have it on a 2A trickle charger now and will probably try some tests tomorrow but the battery is likely toast.
OK, I want to get a battery. Couldn't find the battery type in the owner's manual. Based on some nosing around and probably wanting an AGM battery, I found YTX24HL-BS seems to be the correct battery plus they come charged. Can someone confirm. I am not going to order but buy local so I may not find the specific brand I want or is recommended.
BTW: I didn't leave the key on or have some accessory draining the battery... it just took a dump.
