Yesterday I went to go for a ride and ran into a problem. I turned the key to ON and the lights and initial words started scrolling across the dash, then they went out, it went totally dead. I checked the Hazards and they seemed sort of dim, but it was full sunshine so maybe that was throwing my perception of them off.
I turned the key to off then back on, and this time the dash stayed lit and the words scrolled across, but after hitting the Mode Key, I got all the fault errors, Limp Home, VSS, ABS, ECB(?), DPS and maybe a few others, lol. All the warning lights were on the dash also.
Could this be a result of the battery going dead? After doing some reading on this site, it seems like this could be one culprit that would cause all those errors. Honestly I was so shocked to see all those errors, I'm not 100% that I actually tried to start it up after that, but I think I did and nothing happened.
After saying all that, would either of these 2 products listed below be something I should use to recharge and keep the power level up to where it should be? Not being mechanically inclined, I do not know for sure. As of now I dont even know how to get to the battery, lol. Its a 2009 SM5, but still fairly brand new as it was only titled a couple months ago. I'm nearing my 600 mile check up. I was tempted to call and just have it checked out since I want to get the check up done, but not sure if I should just check the battery out first. I'd really like to drive it in for the check up instead of towing it.
hyea:
Any assistance would be appreciated.
http://www.walmart.com/ip/Schumache...ntainer-and-Charger/13005742?findingMethod=rr
http://www.walmart.com/ip/Schumacher-SpeedCharge-12-Amp-Battery-Charger/13005744
