Need some advice
Twice in the past three weeks I have been caught with the spyder not starting and needed to get a boost.
I have a Spyder RT 2011 and i always keep it on a battery tender.
I took it out again today and had no problems. Checked the battery voltage under the seat and it is showing 13.5 volts. Start it up and the system is showing 14.6 volts.
The only common denominator in both cases was the setting of my recently installed alarm system to on. In both cases the bike was parked for around 45 minutes.
We have a long trip coming up and I have ordered a new battery as a precaution and i have unhooked the positive terminal of the alarm system from the battery.
Is there any suggestions? The original battery today seems fine, however when we are away it will not be on a battery tender, but will be driving many miles each day. With the charging system outputting 14.5 volts it does not appear to be a problem, unless it is over charging.
I carry a Stanley lithium ion jump starter just in case.
