triplethreat
I just did my 2018 RTL. Undo the negative post first. Then remove all wiring. Next you have to get the upper retaining bracket out of the way. Kind of a blind operation, it has two hooks that fit in slots way up in there. Once that is out of the way you tilt the battery out top first. Kind of roll it out. If you use a non-OEM battery the top bracket may have to be adjusted to get a snug fit. I put a Deka in there and had to bend the two retainers in the middle of the bracket out of the way.
One take I had with the disappointing failure of my 10 moth old Yuasa battery. BRP only has a 6 month warranty on their batteries. So basically if you buy the battery from Walmart you get a 1 year warranty, but if you have the dealer install the same Yuasa battery they reduce the warranty to 6 months. Don't fall into this trap. Let the buyer beware.
I did unhook the rubber band that goes to the top retainer plate and remove the retainer plate. I tried to roll it forward, top first, but there is absolutely ZERO slack in the positive lead. So I guess with taking both leads off of the battery terminals would have allowed me to roll the battery out? The whole reason I wanted it out was to be able to attached the pigtail a little easier because the battery sits back/recessed in the cubby hole. Well, at least I know that it should come out that way when the time comes. Thank you for the quick response.
