Base 2014 RT speaker question
Dragonrider
I've decided to add the rear speakers - the passenger controller is in place, is the required wiring there too? Does anyone know if the 14s use the same (Polk) speakers and the earlier RTs?
Thanx!
My 2013 Base RT came with rear speakers are you saying they deleted them on the 2014? Have you checked the balance/fade in the mode menu? The passenger controller has nothing to do with the speakers it is for CB and/or plugged headset music tap. It never did anything for the rear except let the passenger change stations.
The 2014 Brochure does show the RT is equipped with 4 speakers...
Perhaps your dealer should be lookng for a loose connection? :dontknow:
Good Luck!
(Hopefully; all of this will end up saving you some bucks! :thumbup:
Go into the settings for the radio and adjust the fader towards the rear, I put mine on R2. The speakers are there!
Yes the speakers ARE there, however, there was an unplugged connector - works fine now!
Thanks!!
I thought that would be it :thumbup: Don't forget the passenger controls do nothing with the rear volume, why is a good question. It should be set up to lower the volume on the rear speakers or at least change the fader from rear to front. My wife was very disappointed when she had no control over "her" speakers and I when she kept changing my radio station. :dontknow:
