Baker Air Wings
Alberts46
It has been extremely warm here in S. Florida for the past two months. I have air deflectors on my Victory Vision and they work very well and was hesitant to put them on the RTS as I was not crazy about the look. Well they look fine, basically blend in with my Silver RT (ordered the medium tint) and after a test run they work really well!!!. I had more air coming in than I anticipated and it is really nice having control over upper and lower panels independently. The install was a breeze, I think about 30 minutes or less total, highly recommend these. I know in the cold weather between these, heated grips, heated seat (aftermarket addition) and windshield all the way up you could probably go out with a light jacket. You can see from the photo they really blend in well.
Baker Air wings
At 8°F they do help keep the cold wind off-- hasn't warmed up enough here in northern Nevada to turn them the other way since I've had them on. Wife is looking forward to a "warm" ride to test them out.
Have them on my RTS and they look and work great in the hot or cold !!:thumbup: Baker just released an add on for the upper wing that blocks a lot more air or redirects a lot more .
Luv the Baker Wings on my RTS, just ordered the Inner Panel for them, should be here sometime next week. Will post pics when install is complete.
Be Safe
AC:spyder2:
I have recently installed these also. I'm trying to get wind when it is hot out. I have tried deflecting the cold wing to me and they do work, so hopefully it will be better riding in the summer.
I think they look ok, but would really prefer i didn't have to install them. JMO
Can you still check the oil the same way, or do you have to remove the wing first? Will these held divert the hot air on the right side?
You have to take the top bolt off of the air wing.(7/16 wrench) You then pull the entire panel off with air wing attached to get to the oil stick.
They will not divert the hot air on the right side from the vent or the convertor. Spyderpops has mods for those 2 areas.
Will SpyderPops block off work with wings on the bike?
