IdahoMtnSpyder
Well-known member
As we all know the new air scoops for the 2013 heat recall fix make it impossible to continue to use the BRP air deflectors. Well, they also make it impossible to use the Baker Air Wings Inner Panels. I was starving for good air flow onto me since the fix, partly because I have the F4 tall and wide windshield. Here's how I solved the problem of not enough air flow.
I removed the upper Air Wing that is part of the Spyder kit. It is only 1/2 the size of the lower panel. I replaced it with the panel they make for the Goldwing. I ordered the GL1800 replacement wing. I made a new bracket from 1/8" x 3/4" steel bar to provide full support to the full size panel. I reused the hardware from the inner panel and fastened the new panel with the hardware that held the 1/2 size panel. The sketch shows the approximate size of the new bracket. I drew it full size and used it as a pattern for bending and drilling the bar. Cleaned and spray painted the bar.
