BAJARON's wire set
tgflatt
I want to replace the wires and plugs on a 2010 RT with better ones than what came with it. I read in the owners manual that you should not use UN-shieled wires as they could cause interference with the engine control mod. has anybody who has tried the set from BAJARON's had any problems?
Put a set of his wires and plugs on our Spyder this spring and put new vacuum hoses on from NAPA (the silicone ones). VERY HAPPY!!!
Shielding
Ron's wires have, probably, some of the best shielding available for the Spyder -- they are certainly better than the OEM plug wires and will NOT degrade over time as the originals will. I learned this the hard way when the spark plugs were replaced during service on my 2012 RT, but not the plug wires. Suddenly, I had an extreme amount of static in my CB that went away completely once Ron's wires were used to replaced the old OEM ones.
All the best …. Ann
The low resistance, spiral wound, solid core wires in both the MSD and Accel wire sets I sell produce less radio/computer interference noise than the OEM wires while at the same time, delivering more ignition energy to the spark plugs. Plus they last a lot longer.
Honestly, I never intended to sell these wire sets. I simply built a set for my Spyder after discovering the shortcomings of the original set that I needed to replace. Others found out about it and wanted me to make them a set as well. Next thing In knew I was getting phone calls and emails from all over.
2Q==
2Q==
2Q==
