Bajaron Swaybar
Now, now boys and girls! There will be plenty of bars to go around. :lecturef_smilie:
It takes a bit more than owning a 2014 RT to get the 'Test Pilot' nod. Let's wait until you have one of these rare birds in your hot little hands, then put some miles on it so you have some saddle time reference when you install my bar.
Real world feedback from an owner with previous stick time is essential!
My custom sway bar does replace the OEM sway bar. They appear to be nearly identical and I've gotten a fair amount of skepticism from some about any possible improvement from something that looks virtually the same. But there is more to it than size of the bar. The design of the sway bar retention system does not allow for much increase in size so we had to make additional changes to get the stiffness required.
When I put my two bars side by side your bar was clearly larger in diameter. However stiffness is the key! Worthwhile investment for sure!
I just called my salesman today and they still dont know when their 2014 models will be here. I do have a new RT held for me as soon as they arrive. I will have the bar installed the same day I get it home. I cant imagine riding without it installed.
Question: How much difference did the Bar make on your 2013 RT?
(Figuring that the 2014s are a lot heavier; the improvement should be even more pronounced...)
Just got my swaybar last week, can't wait to get it installed and weather warms up to try it out.
Is there pic's or video's of the install of the bar for a 2013 RT-S? Not sure where the white blocks go just yet
as macine is still in storage so I can not check it out under there.
Thanks in advance
