BajaRon F3 anti-sway bar
RNBOB
I just put on the BajaRon F3 anti-sway bar on my 2016 F3Limited yesterday. I rode my usual 40 mile commute this morning and all I can say is WOW.
If you have been waiting to get one don't wait anymore. I've had my F3L for 3 years and this has to be the best change I have made.
Thanks BajaRon.
Thanks BajaRon.
Ya wanna play, you gotta pay. Yep, an excellent modification.
I am new to riding the Spyder. I have a 2017 F3 Limited, just tagged yesterday and have only ridden it 2 days. What is the change you are noticing when you put the new sway bars on? I am noticing a little wiggle in the front end, like tires following the groves in the road. Not sure if it is me or the tires or the sway bar. Bike only has 2280 miles on it.
We are also new Spyder owners, and it does take some getting used to.
I put the BajaRon anti-sway bar on about two weeks after getting the Spyder. It is a 2013 STS SM5, but the handling changes should be
about the same. I felt the body roll in corners was excessive, so after reading posts I bought the anti-sway bar. The handling difference is
substantial. The lean in corners is gone, the Spyder feels more sure footed (wheeled?) in corners now. I didn't really notice any difference
in ride quality, maybe a little more resistant to wind pressure on the road.
If you still have the checkerboard tread Kendas up front, it will wander and follow ridges. A change to nearly ANY fronts will fix that. I run Toyo Proxes t 185/55-15 up front and this bike is non wandering & glued to the direction in which you turn the bars. You will not be sorry you got Ron's bars for sure. Plus the Toyos increases the fun factor by about 4!
Thank you for the help.
Would you change the size from 165/55r15 to the 185s??
Yes. To use the toyo 185 (or any fatter tires) you need to shim your fenders toward the bike using 3/8" lock washers at the bolts stacked 2 deep as shown. Make sure your wires are all as far as you can get them toward the bike and away from under the fenders. Real easy to do.
I have 165/60-15 Vredestein Quatrac 5 on the fronts and am having a 205/65-15 Vredestein Q5 mounted on the rear next week. With the Bajaron anti sway bar on and the new front tires it holds the road and rides much better. I'm hoping the new rear will make more improvements. After 3 years all stock its amazing how much improvement you can get.
Bob
Do you have any concerns about the wheel being able to safely manage the wider, 185 vs 165, tire? And is the bead retention the same on the Spyder as it would
be on a automotive wheel? I know motorcycle wheels and automotive wheels have different bead retention profiles.
Both the stock wheels and tires are car type, not motorcycle. There is no problem. The only problem you would have is if you tried to mount a motorcycle tire on the stock wheels. Tires have a wheel width range that works. The 185 will not have a problem on the stock wheel. This is the size I am running.
Wonderful news to hear. I had concerns because the tires are labeled "For Special Motorcycle Use Only".
The only reason they say this is to keep someone from putting them on a car. Not only are they much too light duty to handle the weight of a car. But their poor construction design and quality would be a very dangerous combination on anything that weighed much more then our Spyders. I think it also helps bring people back to BRP for tires as they think they can't put car tires on the OEM wheels.
I have 165/55/15 Federal 595 EVOs. The handling is much sharper and ride smoother. 1 wheel didnt even need balance weight.its a v-rated tire also. Now i have a BajaRon swaybar, but 1st shop quote of $750 to install it was ridiculous for a '17 F3S. Hopefully I can find a decent shop to take care of it.View attachment 185229View attachment 185230
That is a pretty ridiculous amount for a sway bar install. Not to mention that the F3 is one or the easiest bar installs of any Spyder. When they quote you a price like this, they are actually telling you that they don't want to do the job at all. Usually, because they don't know how to do the job. Instead of getting a better job for the extra money. It's usually worse. Sometimes incredibly worse.
You should not have to pay any more then $150.00 for the install.
So the swaybar thread turned into a tire thread. I have over 17,000 miles on my 2015 F3. Stock swaybar. I still can't come to terms that changing one steel bar for another one will do one iota of difference.
If you only corner at slow to moderate speeds, you won't see much difference, although it's there. But ride more spiritedly and you can't help but feel the difference.
It most definitely do make a difference. If you're not a gearhead, you probably don't understand why but, when it comes to anti-sway bars, bigger is most definitely better.
