So before I get into this project does anyony think I will encounter problems due to my frunk not being opened? Once I remove the 2 bottom bolts, will i be able to pry the frunk forward while the frunk lid is closed?
You may encounter difficulties.
The instructions require you to remove
4 bolts that hold the frunk in place and take off the cover plates over the two top access panels one of which is for the BUDS connector.
You need to open the frunk lid in order to remove the two access panels. Removing the
FOUR bolts and the two access covers allows for the frunk to wiggle out of the way. It's debatable whether or not removing two access panels on top is required, or merely "more better", but if you only take out the two bottom bolts, the frunk will remain immobile.
You need to move the frunk out of the way to access the two upper bolts on the u-clamps that hold the sway bar in place.
Also, there are threads on how to open up the frunk manually by removing the side access panel and reaching up to activate the latch.
Have you read the instructions ?
Not everyone has the same degree of ability. If you are having this much trouble understanding the instructions, perhaps this may be beyond your talents.
If I was closer to you, I'd be more than happy to come over and help.
