IdahoMtnSpyder
I don't find an answer here for this specifically, so will go ahead and ask.
I installed Jim's SmoothSpyder on my '13 RT last week. I guess it's the new style as it bolted into an existing hole, no drilling required. It was tough to get the idler force set as the scale moves quick at the point where the pulley just touches the belt, but I'm quite sure I got the force set somewhere close to 10 pounds. The belt tension was set at the dealer just a month or so ago and I'd ridden about 700 miles before installing the tensioner. Previously I had significant vibrations at about 69 mph (odo reading). I don't recall that I had occasion to drive at 80+.
I just finished about 700 miles these past 5 days on two lane roads and Interstate. The vibration at 69 is pretty much gone. But, here is the rub. I have real bad vibration in the speed range of 78 to 81 mph GPS speed (80 to 83 odo reading). This is exactly the speed I like to run on the 75 speed limit Interstate. The vibration isn't constant, but is present a good 10 to 20% of the time. It doesn't readily die off by either slowing down or speeding up. In fact I think it continued to around 84 or 85, odo reading, which is fast enough to get in trouble on a 75 mph Interstate.
What do I need to do? Increase the idler force to around 15 pounds maybe? Drop the belt tension? I have to make a change of some sort as this bad a vibration at 80 is unacceptable. That is the speed for a huge percentage of the Interstates I travel.
I just looked at the belt and the tension looks to have stayed at the same 240 pounds, Kriket reading, I measured right after the dealer adjusted it. The tensioner looks to have moved so that the outer flange of the idler is pushing the edge of the belt. In fact the belt is up against the flange on the wheel sprocket. It had been tracking about 1/8" away from the flange. Is the idler pushing sideways on the belt contributing to the vibration, or did the vibration cause the tensioner to move. I'm sure I had the idler pretty much centered on the belt when I installed it.
