Bad Vibrations- anyone else make a dampener kit?
Mosess01
Called this gent down in Florida and he smooth spyder .could not understand a word he said. Tried to buy a belt tensioner. Sense I did not understand the guy is there any one else that make a kit.
Sent from my SM-N910V using Tapatalk
Mosess01 it appears that English isn't you native language. Having lived outside the US and not being able to speak the local language, I understand completely. You might want to find someone that can help you as a translator, to help solve your issues. Jim (Smooth Spyder) is an old fart but his English is normal. A few ago you had a pretty negative thread and it is obvious that you are angry with BRP and maybe your local dealer. I certainly understand that too. BUT I think that if you can find someone that can translate and knows a little about your bike, life will be easier.
Bad Vibes
My English is just fine, I was in a very foil mod the day of this occurrence. An yes I do have a beef with BRP. as many of you should also be very upset. If the vendor had spoken up just little so I could understand him we would not be having this pissing contest. So take cares , Know with that said Pilzerwm .I am not one of those good old boys . I am only here to gather info to make my riding more enjoyable so I am not the one okay,
Before you spend your money, reset the belt to the lower specs published in the service bulletin.
OK, So what is the problem? Belt vibration? Tire? When does it happen? Does increasing or decreasing throttle help? Make worse?
Details, please.
