My 2008 RS with 22,000 miles started to have an oil leak around the front drive belt pulley. After removing the front drive belt pulley it was determined that the bearing is bad thus allowing the pulley to wobble. I was wonder is anyone else has had similar problems. Looks like it is going to be very expensive to fix as the engine must be removed and the case split to get to the bearing. Seems like you should not have a bearing going out on an engine with 22,000 miles.
