Ladyjfrancis
I have a can am Ryker rally 2 up. Riding 2 passenger up. I would also like a backrest for my back. Have not seen any products out there on the market. Please help!
			Slingmods have one you can pre order. I saw the picture way it looks you can't use passenger seat with it. Looks like metal supporting bar goes thru the hole where you lock the passenger seat. I saw one on FB someone bought backrest from Amazon and fabricated one to fit driver seat and still able to use passenger seat. I can't seem to find it now.I want one as well.
I had heard late last year that Slingmods was working on one.
https://www.slingmods.com/canam-ryker-adjustable-backrest-show-chrome?vehicle=4
I am in the process of fabricating one using the Can Am LinQ latch. I was working on it today. I plan to make a combination driver backrest and luggage rack Only the whole thing will be removable using the LinQ latch. You can buy them OEM replacement in a box of two on ebay. It's going to take a while to put this thing together because I haven't welded in about 40 years, and then it was stick welding. I picked up a Mig welder and have to do a bit of experimenting before I can claim a decent weld.
I did see a removable driver backrest on YouTube. There is a woman ryker owner on there that has made a few videos of her installing accessories and she showed how this removable back rest works. Not sure who manufactured the backrest for the Ryker, but I am sure that if you watch her video, you can find out who after markets it.
Ok, so an update on my bit of fabricating of a driver backrest/luggage rack combo. You can purchase a box of two LinQ OEM locking latches so I started by attaching them to a steel plate that I then attached a backrest pad that once was attached to a sissy bar on a motorcycle. It looked real good and it was easily attached and removed using the LinQ latch. The luggage rack will be welded to the steel plate of the backrest. But, first I had to try out the driver back rest. I mounted my Ryker and took off, and literally "took off." I didn't get two driveways in our neighborhood before the surging weight of my acceleration pushing me back in my seat when I lost my back rest. Yep, the LinQ latch could not take the stress caused by the leverage of my weight on the back rest so one of the ears(?) that held he latch from below the max rack, snapped. It's made of plastic so I should have thought of that. Ok, so I have another LinQ latch. But, I do learn from my mistakes so I am going to use this one solely on my luggage rack. The back rest will be put on the rear burner for now.
Regarding the question about being able to put the passenger seat on with the back rest mounted, NO it would not work that way. My intention was to have the luggage rack and back rest as one unit. I figured that if I had my other half in the seat behind me, then I had a sufficient and optimum back rest.
My goal now is to piece together a luggage rack with saddle bag standoffs. Win some, lose some.
