IdahoMtnSpyder
Well-known member
I considered doing that exact same thing, except with a threaded rod somehow. I can't figure out anyplace to get a good solid anchor on the swing arm to pull hard on the rod. I'm not sure a ratchet strap would do the trick because regardless how tight you pull it there will probably a minuscule amount of stretch in the strap, and if the axle moves the least little bit while tightening the nut it throws the tracking off. And finding room between the swing arm and muffler to grab the end of the rod would be a challenge.I have spent many hours trying to get my 2015 RTS aligned. I finally got it but it was a battle. I have a thought but haven't tried it yet. What if you took a steel rod and ran it through the axle bolt and held each end tight with a ratchet strap. I don't think you would need much tension on the straps just enough to keep the adjusters tight. Has anyone tried this by chance? Do you see any issues with doing this?
I think the best solution is lube under the washer, start the bike, and run the tire forward and backward.
I talked to the service manager at the local dealership the other day about my travails. He understood and sympathized indicating they have a lot of trouble many times getting the tracking just right. When I said I finally got it he said, "You did good!"
