Avoiding Road Hazards on 3 Wheels?
bob, the edge of a tire has a better chance of puncturing then the tread area, that is why the rear would
be preferred if you have to hit since the rear has a wider girth.
Spyderpops BUMPSKID
I have found this invaluable on roadkill or in case I just created road kill. Plus protects your :spyder2:
And if you have some fore warning...slow the heck down, throw on the flashers and pick your path!!! :yes:
It is simple for me. I ride behind my wife. If she sees something that needs to be avoided and takes corrected action, then I make the needed adjustments for my spyder. She has a Suzuki C90 Trike so we are both riding on three wheels.
In general I think you are far better off taking the hit with the rear wheel. Any front end hit can foul up the alignment and would have a greater potential to disrupt your steering. The rear wheel is wider (might span part of a small pothole) and the suspension should be able to take most hits without damage..
I agree also. I had the hardest time figuring out what to do when I started riding three wheels. My habit (from 4 wheels) was to split the hole or debris. That didn't work so well sometimes. I found that being left-handed I could thread the needle from the left wheel and the rear wheel better than trying with the right wheel. I usually try that and if it's big enough to not miss, slow down and take it on the rear tire. That has worked best for us.
Consider it training if you ever get to visit Louisiana. My best empty spot seem to be just to the inside of the R front, clear the hole with the space of your floorboard / peg. Yes slower is better or just keep eyes on traffic in front of you see where & how bad they dodge, act accordingly. G'LUCK.
