Well I just bought a 2020 RTL, and thought the same thing..... Why didn't Can-Am just leave the windshield where you use it. As to why... It seems pointless and adds to the whirling of thing going on when you shut it off/on, and adds that little bit of time with the whole process. Plus just more wear on something that could break.
I note in both the 2020 and 2021 operator's guides there is no mention in the Switch Cluster section about the automatic lowering function, just "press here to raise" and "press here to lower." Have you considered pressing the "raise" portion of the switch when turning off the engine with the ignition key? If you turn off the engine with the Kill Switch does the windshield automatically go down? My engine must be running before the switch will work.
AHHHHH.....FOUND IT.
Check out this video. Fortunately, the discussion of the windshield is in the beginning from about 23 seconds to 50 seconds.
The demonstrator says hold the windshield switch in for 3 seconds and the windshield locks in place.
My 14 RT windshield doesn't move ....unless I use the switch to do it ...... sounds like BRP added something that wasn't desired ..... Mike :thumbup:
When you turn your key back on, dose it pop back up to your last setting?? It sounds to me like there's a relay or some thing in that circuit that hold everything at bay then when the powers shut down it goes to a rest position when shut down!:dontknow: There are some clever guy's on this site that could probably come up with a fix to this issue!! COME ON GUY'S you can do it!!:chat:
lTried to make this work.... Can't maybe I'm doing some wrong
., but long press just rises or lowers.
