Bert, just on the above, our Aussie design rules mandate that additional fog lights (we call them driving lights out here) must have their own switch, but can only be activated via that switch when high beam is in operation, so they also need a trigger from the high beam wiring.
Pete
You can run low wattage
Fog Lights in the same manner only paired with Lo-beam Pete (I think it's a 35w maximum, but haven't checked for a while...
pps
And you can also run '
Daytime Running Lights' with a wattage limitation too, only they should turn
OFF if either your Lo or Hi beam lights go
ON!! (altho as I'm sure you already know, heaps of wannabe boy racers in their cars don't limit the wattage or turn off like they should tho! :sour: )
Btw, Driving or Spot Lights don't have that wattage limitation, 'Driving' being the lights with a spread beam pattern & Spot lights (obviously
) being those with a long distance 'spot' beam pattern having little light spread onto the verges - but as you mentioned, those Driving or Spot Lights and in fact
ANY forward facing Main or Aux Lights will need to have their own trigger switch that is
meant to work to activate them
only when the appropriate main beam is on (or off, as applicable!!) :lecturef_smilie:
As for your Projector Lens concern Bert, I don't know if we get different P/Lenses than you do over there (they don't appear to have any different part numbers tho??) or maybe it's just that BRP's P/lenses
AREN'T actually '
designed' as such to work with those shutters that you lot get in the USA, but that's just the way your country has decided to satisfy whatever odd law/rule you have that resulted in those shutters?? :dontknow: But here in Oz, the P/Lens itself is definitely a Projector Lens, but as far as I (and some others who are far more technical & authoritative than I - my local Roads & Traffic Compliance Inspectors
) can work out, there's no 'shaping' of the beam pattern as such built into the lens - so the beam pattern output all comes back to the positioning, 'clocking', and the design of the light
source... And that means that a really bright Lo-beam globe should work really well to resolve Askitee's dim/useless Lo-beam issues,
except for that bloody heat issue with the poly lens cover :banghead: And that's why the better quality LED's work so well - low heat output along with lotsa lumens! Similarly, our Hi-beam P/lenses in the upper light assembly's work in the same way, it's the positioning, 'clocking', and design of the light source that determines the output beam pattern - the Upper assembly's work really well and provide the necessary beam patterns when a standard Hi-Lo Filament or HID Globe is fitted, as well as when quality LED's designed to work as Hi-Lo lights are fitted too!
hyea:
Just Sayin' :cheers:
Ps: I can't remember exactly which Hi-Lo globes went in, it was just too long ago - but they were readily available. I took in the globe that came out of the upper light assembly & got a couple of 55/60w equivalents... and then later got JB HiFi LED equivalents.
