MrLooney
Senior MOMENTS Member
There are a number of wires on both sides of the frunk that have to be removed. with a little patience they are easy to remove. A sensor of some kind ? ?
These are Fog Lights and wires that pops off easily.
A second close up of the sensor ? ?
A view of the Naked front of my Roadster 2011 RS~S with stock shocks and Ron Bar! Well worth the expense even for the novice ryder.
A new pair of multi tone horns were installed. These are the mounting brackets that I modified to adapt to provide adequate clearance for suspension movement. Note the bracket on the left has been modified. The bracket on the right is stock from factory.
