Audiovox Vaccuum Line
Hamie
I have looked at the installations here on the forum and I may be just overlooking it...but...where do you hookup the vacuum line to the engine.. Thanks....
This photo doesn't show the precise location, but I tapped into the vacuum line with the T-fitting in the kit and ran out to an auxilliary vacuum cannister. The vacuum cannister was purchased off of e-bay - benefit was to provide more consistent vacuum response regardless of engine RPM.
vaccuum line.
I connected my cruise vaccuum into the line that runs down to the vaccuum assisted clutch.There is non-return valve in this line, before the electric switch ,that is where I put the tee.This is on the right hand side of the bike, just in front of the purge vale and cannister, before the radiator.Sorry I dont have no photos.I put the sensor magnets on two bolt heads that I added to the rear disk.Works great.
Eric.
Thanks for the replies... had this cruise control on my FJR and now looking to install it on the Spyder... I used a gas filter as vacuum canister and worked great...
Thanks... found an image that shows the tee in the vacuum line... think I will get the Kewlmetal Performance Air Filter before installing the cruise control..
