ATV Jack
TopCat
attachment.php
Has anyone purchased/used this jack from Harbor Freight. Just high enough to put some jacks under the front end. Noticed that there is a 300# weight limit. Your feed-back would be appreciated. Thanks.
lawnmower lift
I believe it is too narrow and will not meet your weight requirements - if for your Spyder!
attachment.php
300 lbs seems a tad on the light side for lifting the front of a Spyder... I have a 1700 lb ATV jack... rather be sure than sorry... paid $116.00 from Amazon
osm
Don't know..!!
have seen them but find little use lifting the front end and not being able to work on the wheels, brakes etc. They also offer other lifts
attachment.php
they have the yellow on in blue.
attachment.php
and goes up even more..depends on what your going to do...:thumbup:
Haven't had great experience with HF, they take forever to ship. Also it looks too light weight for your needs.
I have the exact same yellow ATV jack asChupaca and as well as a 3.5 ton floor jack. I found mine online at Sears for a good price which I now forget exactly what that price was.
JT
Chupaca - That's exactly what I have, with a 3 ton jack and 10 ton stands. I've used these for all three spyders, ATVs, SxS, and several two wheelers. Both jacks were sourced from Northern Tool, and the stands from NAPA.
Same jacks work ok lift handle springs clips come off if you're not careful the low profile racing Jack also works for wife's car 325 bmw
To put it crassly, IMO the brand name for HF stuff is misspelled. Change the TT to S and it's more like it. Most of their items are CCS products. Cheap China S***
Front Lifts
TSC- Tractor Supply Co. sells two different models of these lifts and I believe that thy are rated for more weight than this one shown here.
