blitzkreig
Had two total knee replacement surgeries and I HIGHLY recommend that solution ... if the pain gets bad enough.
No one can tell you when that pain is so bad that you will put your self through such surgeries as cutting the top and bottom off of your knee joint and replacing the joint entirely with a metal alloy ... separated by several months of physiotherapy only to do it all again a year later on the other leg.
But that said it is a 100% fix.
