Arr MiHardies' New Mod Thread
Arr MiHardies
It has been a long time since I updated my mod thread, and a lot has changed, so I figured I'd just start over and get everything listed.
First, a list of my mods. I will follow this with posts containing pictures.
SpyderPops Bump Skid
SpyderPops Heat Shield
KewlMetal Honeycomb Grill
Xenon Depot HID Lights
Removed fuel gauge and temperature gauge to move their readouts to the display.
Stage 5 Elkas (front) with higher mounting position
Stage 1 Elka (rear)
TricLed Fender Lights
TricLed Adaptive Headlights with dimmer
Custom Fender Running/Stop Lights
Custom Fender Turn Signal
GloRyder Wheel Lights
Spyder Sisters Frunk Lid Organizer
Left and Right Ram Mounts on dash
TricLed switching Fuze block.
Volt meter with digitized analog readout
Custom in dash 12V accessory outlet
Corbin Seat with driver & passenger backrest
Custom Console garage door opener
CustomDynamics high brake light
TricLED Halo Kit
Lots and lots of custom lighting using strips from TricLed
Lamonts NVB Highway Pegs with Kuryakyn Pegs
Custom SpyderWeb Rear & saddle Cargo Lid Storage webbing
Two Brothers Vale M5 Titanium Exhaust
Bluetooth Media Dongle installed in rear trunk
First the current state of the lighting:
IMG_20130215_185641.jpgIMG_20130215_185623.jpgIMG_20130215_185603.jpgIMG_20130215_185554.jpg
Custom Fender running/stop/turn lights:
Garage opener (The green lights next to it are obsolete now)
Glowing air deflectors
attachment.php
Cargo Lid "SpyderWebs"
attachment.php
attachment.php
Custom dash mount 12V accessory outlet.
attachment.php
Bluetooth dongle installed in rear trunk. ipod mini and ipod adapter brick mounted to side wall with velcro. dongle mounted with sticky backed mount included with kit.
Stage 1 Elka (rear)
TricLED Halo Kit
WOW...That's alot of mods! Can't wait to see some pics. :clap: :thumbup:
Installed the Bluetooth media dongle in the rear trunk last night. This was a pretty easy install. The factory included instructions were useless. Bt its still pretty easy to figure out. Remove the cover over the radio. Remove rear body panel. Drill hole next to iPod connector. Feed wires along same path as iPod cable and through their new hole. Install weather seal.
Works really well. Only complaint with this was that the cable provided by BRP has a female audio connector. This makes zero sense. Because this connection is female, we have to use an additional (included) male to male audio patch cable to connect the cable to the dongle. If this connection were male instead, this additional cable wold not be needed.
One ing I did not expect was just how tiny this dongle is. I have the Sena two way radio Bluetooth adapter, which is 4 or five inches long and about 2.5 inches wide. This dongle is maybe 2 inches by 1 inch. Tiny little thing, which is a welcome surprise since it is taking up precious cargo space.
