Are there any other reputable brands of Oxygen Sensor that work?
RangerRick
I'm trying to see if Bosch or other reputable manufacturers make them for my 2013 988cc. Can-Am wants around $115.00 a piece. I see cheap China ones online but no thank you. Tried searching on here but can't seem to find anything. ;)
If you have an HEGO (4-wire) then you can splice in an NGK, Bosch, etc.
If you have a UEGO (6-wire) the sensor-side connector contains the calibration resistor so you can't splice in another sensor without losing calibration. In most cases if you remove the sensor you can see faintly stamped into the bright metal shaft the OEM and maybe p/n. It's probably Bosch just like many of the other sensors which you can buy from other sources besides Can-Am.
