Pulled the trigger!
I bought the kit, didn't realize I had to drill holes :banghead:. The glovebox was getting super heated, I had to let my sunglasses cool off before I could put them on, and the cellphone was really hot. I figured the included insulation would cool the side panels (my legs) a bit also.
UNBOX
Wow what cheap plastic! black ABS for the main body, dark Lexan (?) for the front scoop. I saw in a years time a huge faded scoop, and super scratched up lexan nose piece. So, since it's already black, out came the PlastiDip! Put a lot of layers on, let dry overnite.
INSTALL
Kit came with no instructions, so found the heat kit instructions here, they cover the scoop at the end. The instructions give you a template to cut the vent hole open more to match the scoop. I was :yikes: scared to do so, but since the panels have holes in them now, I may go back and open them up if airflow isn't great. I think at 70mph there should be plenty of air being pushed across the engine and glovebox area.
The instructions say to use a spray paint can tube (like a WD40 tube) and some paint to mark the panel, once you have the scoop pressed against it tightly. I have a "dental tool" kit, I just located the best I could and put a poke in the paint. The fun part is after that, you have to go back and forth and guess where the actual drilled hole goes. I started with a 1/16" bit and guessed - all wrong. I used the dental tool to poke through the hole into the scoop to see how far off I was, then re-drilled. Once I got it, used the bigger drill bit. A couple times I had to file a smidge. I only installed 3 screws, one top, bottom and rear. I remembered after I was done (of course!) the trick of using lipstick on the holes, and pressing against the panels so I could actually see where the hole goes. Dunno if it would work, would have to be pro at pressing into place without smearing...
The kit comes with a shiny strong bar to replace the big plastic cover (the one you take off to get to the oil filter). That went on easy. I show a pic of the socket on the oil filter to show it's a snap to get at now.
FINI
Since I plastidipped all the "dull aluminum" parts already, the scoops look great. Might be my imagination, but the dash seems to vibrate a bit less with the metal bars. This is NOT a project for the faint of heart!! You can't undo it unless you know a bodywork person to fill the holes and paint the panels.
Note: the pic of the scoop shows the reflective pinstriping I put on. Just followed the contours all over the bike, and the edge of the windshield. I also plastidipped the bottom of the windshield and the covers. Comes off easy if it gets torn to re-paint (haven't had to yet - it is holding up VERY well).
