IGETAROUND
sensitive to road crown
Not so much looking to ride with no hands as looking to be able to relax and enjoy he scenery. Cant really do that if youre constantly having to keep the thing going straight. Riding loose and letting it do its thing helps but tell that to my wife. She hates it right now. Doesnt even want to ride it now, and i got it for her, not me. Going to take it out with the higher rear air pressure in a bit to see how that affected it.
Well ive beaten this topic to death, we will ride it more, get an alignment, and check in after some time. Thanks for everyone's input and thoughts.
I don't ride your model; however my ? to you is how many miles have you under your belt on the Spyder. Same ? for the wife. If you have less than 1000 miles give it some time. The sensitivity to steering input of these vehicles is truly amazing!!
As mentioned the front tire pressure needs to be as close to identical side to side as you can make it and I would respectfully suggest you not go above 18 to 20 psi in the front. If you run 25 and up in the back; you will more than likely experience wet road traction issues.
Almost all spyders need a laser alignment; according to the spyder experts less than 1% are properly aligned when delivered to the owners. It does make a marked difference in required corrective input crowned road irrespective.
These are a pleasure to pilot when set up properly; they are a nightmare until then!! The first $ invested in making it yours is to get a ROLO laser alignment by someone who does a lot of them. That would be Ann and Joe Meyer or Spyderpops or the gentleman in Houston (sorry old fart moment on names).
Then get some miles under your belt 1-2 thousand and I believe that you will have a different opinion than you and your spouse currently have. Just MHO
Al in Kazoo with 40 K and counting
After looking at your home state; you might want to take a trip to NESTLE's (sp) in upstate New York, they will treat you right and get your ride "squared away " properly. Some one will come by and spell the shop name properly for you, be patient please.
Al
Al
