I am still trying to figure out this hyperflash stuff.
Today, I installed two load resistors, one on each of the front turn signals, in an attempt to correct my hyperflash situation. Initially, they made no difference. I then disconnected the TricLed sequential fender and the A-arm dual mode units and load resistors then tried a "reset" of the Spyder's basic turn signal rate. All was temporarily back to normal.
A brief history. My first led add-ons were Custom Dynamics led fender turn signals - these caused no issues. My next add-ons were led turn signals to the side cases - these also caused no issues. The latest were the TricLed units, which replaced the Custom Dynamics units and this is when the hyperflashing began. The Custom Dynamics system had all of the turn signal leds on one run, so they all came on together.
The TricLed's actually have separate flasher "controllers" inside each of their respective wiring harnesses and everything runs as marker lites until the turn signals are activated, at which point, the Spyder's system sends the signal to each of the TricLed's harnesses thru the connected turn signal wires. The sequential fender units appear to be operating normally (speed wise) by themselves, however, the remaining turn signals all behave erratically and randomly.
I had a 20 minute period when all appeared to be fine after putting in the load resistors back in and the flash rate was normal. Then, just before buttoning everything back up, I did a final test and started getting anywhere from fully hyperflashing mixed with random half and half mix, similar to an engine starting to miss. Seemed to vary depending on whether the engine was running or not , but there was no particular definite pattern either way. I pulled out the resistors without any change being observed after that.
I contacted TricLed and it was suggested that I add two 300 ohm, 1/2 watt resistors, in-line on to the rear turn signals. Does anyone with any electronic knowledge have any experience with such a set-up or have any other clues or suggestions? (I have tried all the on-line reset procedures to no avail) I am willing try anything so I don't look like I am pumping out machine gun bullets while stopped at a traffic lite.
Thanks
:chat:
