Anyone using these OEM Oil drain plugs with hex head?
Tourer
Have read here that some aftermarket hex head replacement oil drain plugs have broken off. Some say it’s because the thread wall is not thick enough because of the magnet. Some say it’s due to over tightening. Saw this OEM one below on a Google search. Comparing pictures of the Show Chrome and this one, it seems the magnet is thicker in the Show Chrome. Anyone using this OEM plug?
https://leadersrpmshop.com/can-am-n...MI5qXR9oOr-gIVex-tBh0SXQeyEAQYAyABEgLAVvD_BwE
Edited this post because the above link doesn’t come up anymore???
When these re-placement plugs appeared on the market There seemed to be more Failures with the DIMPLE Brand ( I don't think they are made now ) ..... and the failures were due to a too thin thread wall or overtightening which damaged the Alloy Pan ... I don't recall the HEX insert plug being an issue just the engine bolt type ..... JMHO .... Mike :thumbup:
I just order one for stock...Will compare it to what ever brand hex plug I have at my next oil change over the winter...THANK YOU for the link...larryd
Lamonster has these on his website, think they are called 'gold plugs', set matches exactly what you need, reasonably priced as I recall. For me, the OEM plugs were a real pain.
I been using the Gold plugs since the first oil change @ 600 miles. Never had a problem. Over tightening is the main cause of stripped threads or broken plugs.
Used hex head magnetic plugs in the primary drain of Harley Sportster for 350,000 miles before I bought the Spyder. Never a problem with it either.
