Anyone tried Rotating their front directional tires? Worth it?
Anyone had their front directional tires remounted and rotated? Was it worth the cost? Any other thoughts?
As in dismount the tires from the wheels, and then mount each tire on the opposite side, making sure they're still rotating the correct direction?
Yes. It cost me $60 to mount and balance the tires when new. I expect to have to pay a similar amount for the mount and balance.
This post should answer your question especially posts #11 and #17.
Thanks. Did a search before I started but did not find anything. Maybe I need new glasses.
If the alignment and balance are good, you shouldn't need to rotate front tires. If they aren't and the tires show noticeable wear patterns, it's probably too late to save them with a rotation anyway.
Always rotate my tires. I back it out of the shop and rotate them in reverse for about 100 feet, then I put it in 1st and get them started rotating in forward for a while. About a mile of dirt road in 4th gear and it comes to the highway. Then I rotate them faster.
