The 175/60R15 Kumho KH17's
DO fit up front with the 2013 & on fenders with the raised rib on the outsides, there's quite a few of us in Aust running them now; but that doesn't necessarily mean any other make of tires labelled with that same
Nominal tire size will fit too - even if any/all of the tire comparison charts & calculators on the internet tell you they do!! :shocked:
You simply can't tell unless you compare the dealer published rolling dia & width info with that of a 'known to fit' tire like the Kumho's; because any given tire's
REAL dimensions won't necessarily match every other make of tire that happens to be wearing the same '
Nominal' tire size!! :shocked: Yeah, I know they
should - but they
DON'T!!
That said, the Kumho's are more of a 'sport-touring' tire than the Toyo's that have a more performance oriented tread & compound mix - so the Kumho's might lose a bit of outright grip & sports performance to the Kumho's but counter-balance that by wearing better/lasting longer (at least when you run them at the appropriate pressure for the load they are carrying) but
BOTH tires are still waaaaaayy ahead of the Kenda's in
ALL respects, just a little different in each of their particular strengths! :thumbup:
