:roflblack: But mounting the microswitch on a wheel chock could be problematic. :roflblack:KISS - use a chock, there's nothing simpler or less expense, or as fool-proof ..... JMHO .... good luck .... Mike :thumbup:
The following scenario.
Elderly person with strength problems.
Riding solo.
Need to park on a slope.
How to get the chock out of the trunk and behind the rear wheel all while keeping the foot on the pedal? Even with chock in pocket, still hard to get it behind rear wheel with foot on pedal.
POSSIBLE SOLUTIONS
Stay home. Not really an option
Use trailer hitch or similar frame to hold swing down chock mechanism that is deployed with a pull cord coming out under the seat or between the panels. good only when parking up hill.
Riding solo.
POSSIBLE SOLUTIONS
Use trailer hitch or similar frame to hold swing down chock that is deployed with a pull cord coming out under the seat or between the panels. good only when parking up hill.
Since Spyders stay in gear until you restart them (at least that's what mine does) no need to worry about the brake or a chock. Unless you feel the need to find neutral manually upon parking, but why would you? Even if the elderly person's Spyder does not do that, they could keep the chock strapped to the back seat and keep a foot on the brake while they get off, then put the chock behind the right front tire; parked uphill of course.![]()
Next time you are out give it a try. Since the clutch is not engaged it will free roll.
Why would you not just fix the broken parking brake?
This is not true for semi auto Spyders. At idle or bike off, the clutch is disengaged so it does not matter what gear its in, it free rolls.
Mine does not free roll until you hit the mode button followed by the starter button. Then and ONLY then does it shift itself into neutral. Otherwise, it stays in gear and resistance from the transmission can be detected when trying to roll it. Yes, I have tested it after leaving it in both 1st gear and reverse.
As for the wheel chock discussion, that arose as a more or less tongue in cheek comment by BLUEKNIGHT911.![]()
