Anyone Have a Big Ass Drink holder?
From back in the day when plastic insulated 32 oz cups first came out I had a cup holder for one that I cut the clip off of and screwed a ball mount onto it and used it for awhile and that worked. Maybe if you can find something like that it would work. Mine has long ago disappeared and I use one from Diamond R but the cup is too small,but the Ozark Trail 30 oz. from Walmart will fit it part way.
I bought a Kemimoto ATV Cup Holder from Amazon. I mounted it on the left bar as close to the switch cluster as I could (on a '21 RT LTD) whilst not bending the cluster cables too much.
But I had the bottom of the holder towards the center line of the bike. Big mistake. Whilst turning around in a parking lot, the bottom of the cup holder touches the ignition key just enough to turn the ignition off.
So, I had to tilt the holder so the top points towards the center line instead.
There is not a lot of space on the bars for mounting items such as this due to the angle the cluster cable harnesses come out of the cluster from. I've no idea how I would mount a 32 oz holder?
