Anyone had a problem with a new crossover pipe on a 17 RT? What else could it be?
rperry
Has anyone had a problem with a new crossover pipe on a 17 RT? I have about 700 miles on it since instillation. Last night I stopped for gas and when I restarted it, it sounded like the pipe had come apart. Got under it this evening and everything is tight and looks like I think it should, but it still sounds like the pipe came apart. I HAVE NO CLUE! Any help would be appreciated.......Oh, I am going to go ahead and ride it until I can find an answer.
Are you sure your springs are still in place and in good condition? Those exhaust donuts usually last a very long time. And you're sure the leak is around the donut?
Riffing on what Ron said, make sure you have all three springs at the front. Following his suggestion, I dropped the cat converter and the pipe in front of it, put the springs on, then put the whole thing back. Also it is possible to put those joints together without the donut. So please make sure you really have what you think you have.
Yes, the springs are there, they are tight, and everything looks good. I let it cool down and there was nothing in any of the line of exhaust that I could move by hand.
Start it up cold and run your hand around in the vicinity of the noise, (carefully as it will heat up fast). It is not necessary, or advisable, to actually touch anything. You're just looking for air movement to pinpoint the leak.
