I found an app called rev for the iPhone that is really nice.http://www.spyderlovers.com/forums/...trics are specific to vehicle make and model.
http://www.devtoaster.com/products/rev/index.html
Rev is the first and best iPhone application to connect directly with your vehicle.
Rev is an application for the iPhone and iPod Touch that monitors, displays, and records real-time vehicle data. By communicating directly with your vehicle's ECU via its OBD-II port, Rev is the first iPhone and iPod touch application to give you complete access to everything you want to know about your vehicle. Real Time Metrics
Rev can monitor and record several vehicle metrics in real-time:
I downloaded the lite version and the skidpad and GPS monitors are really good. I was wondering if anyone has used the wifi odb-II dongle with it I would like to be able to check fault codes and monitor things like throttle position, steering angle etc. I am not sure what codes and metrics are available for the spyder. If you have used this or connected a PC to your Sypder throught the ODP2 port could you let me know what metrics it supports
I am using my iPhone as my motorcycle computer. it gives me phone and wifi and gps. I have a J& M bluetooth headset and it is great too. The mechanical quality of the device is execlent and the speakers are the best I heard it support stereo also. I have tom tom installed on my iPhone and it works well. With voice command i can control my ipod music and make and receive calls. I can also hear the voice directions from tom tom. I listen to pandora around town through the 3g connection. always have access to the weather channel and live radar too. With the adition of Rev and the odp-2 Dongle I should have pro grade performance monitoring and logging too.
again if you know what metrics the Spyder ODP2 port has post it here
thx
- Vehicle Speed (including 0-60 time)
- RPM
- Fuel Consumption
- Engine Coolant Temperature
- Fuel Pressure
- and lots more! *
thx
