Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
There were many reasons for the change of the site software, the biggest was security. The age of the old software also meant no server updates for certain programs. There are many benefits to the new software, one of the biggest is the mobile functionality. Ill fix up some stuff in the coming days, we'll also try to get some of the old addons back or the data imported back into the site like the garage. To create a thread or to reply with a post is basically the same as it was in the prior software. The default style of the site is light colored, but i temporarily added a darker colored style, to change you can find a link at the bottom of the site.
Um. Tex. I hate to surprise you like this, but there is no clutch cable on a 2012 RT sm5. It's hydraulic. There's fluid in that reservoir right there by the clutch lever. Specifically, DOT 4 brake fluid. Refer to your operator's guide for maintenance instructions. If you don't have an operators guide, you can download one here for free.
Professional Keyword Searchable Factory OEM Manual - 1169 Pages !! New updated full digital version as of 2022 !! It covers the 2012 Can-Am Spyder RT (Auto, Manual & LTD) Series Including the Spyder trailer. This manual contains hundreds of pages with extra content that the expensive book...
Ha. I don't think you hated that at all. LOL Anyway, my clutch lever is sticking. I assumed that since there is a cable running from the lever down into the guts of the machine, that it was a clutch cable. Any ideas on why it might be sticking? It doesn't stick in neutral only in gear. It has plenty of fluid in the reservoir.
Google says the clutch fluid is actually DOT 4 brake fluid.
Google also says DOT 4 brake fluid is hygroscopic.
That means it absorbs water from the air, which degrades it's capabilities over time.
Brake fluid should be changed every two years or 20,000 miles, whichever comes first.
Basically, bleed the fluid until it comes out clear, making sure that the reservoir never goes dry.
Brake fluid should be changed every two years or 20,000 miles, whichever comes first. So since your clutch is hydraulic and uses brake fluid, it too may need regular changing.
Basically, bleed the clutch until the fluid comes out clear. I'm not sure what the bleeding sequence would be, but you have to bleed the entire clutch hydraulic system.
Well Tex. I think the point of all of that ^^^^^^^^^ is to just make sure that you're up to date on your maintenance. Which we already covered. Beyond that, I'm going to sit on the bench on the rest of this. I don't have adequate real-world, hands-on experience with the SM5 clutch. You might want to be more specific regarding what you mean by "sticking". I'm certain someone will be able to help you out. Good Luck.
