Any suggestions on running gravel and dirt roads on a Spyder?
It does not matter how easy I ride and go slow, the RT will scrape on the road.
Maybe there is an aftermarket mod to fix this?
Dirt & Gravel roads shouldn't be too much of an issue, just so long as you take care to avoid running your front wheels down in any dips & so dragging your Spyder's belly on the raised bit in the middle. There are Bumpskids & Alloy belly plates available to minimise damage if you do. Here in Oz, especially where I am, you really cannot avoid riding on dirt and gravel if you want to go anywhere but between major cities (and we don't have a heap of them!) so I've ridden
many 10's of thousands of miles on my 2013 RT Spyder over dirt & gravel roads, altho not so much on the '2 wheel track' tracks that also abound. I don't avoid the dirt & gravel roads, but I do take a little more care, keep the speed down a little, and try to avoid hanging the tail on the loose gravel - and I
DON'T have a 'missing belt guard' or any extra protection for the belt either, never had any issues with that, altho my RT's belt is just beginning to show signs of wear on the 'power edge' of the drive nubbins simply due to the milage it's done! I
DO have an Alloy skid replacement from
@noboot (a member here - that's his username) for the plastic skid tray that goes under the frunk, because it's much less obtrusive & far more beneficial to my riding than a Bumpskid - even the bitumen roads here get upset with those Bumpskids!
In my opinion, the issue with the Bumpskid units is that they are thick and they have a lip which sticks out around the edges of the bottom of the frunk, meaning that that while the do protect the belly of your Spyder if you only ever ride on smooth, sealed roads, they'll only make things worse on anything rougher &/or if you park nose first to close up against anything they can hit, cos you'll hit/hook it up on anything that's high enough to reach it; PLUS they're about 10mm thick too, so you lose at least that much off your ground clearance & more off your approach angle because of the protruding lip! I've seen a few of those that've done some damage to the frunk & underside of the Spyder because that lip has either plowed up/into things that the Spyder would've otherwise slid over the top of; or the lower ground clearance has meant there's been too much force applied on the fixing points underneath, and things have been bent - expensive things!
The Alloy skid plate is simply a stronger, marginally thicker (6-8mm) but much stronger and more durable, and only a slightly larger version of the OEM plastic skid tray, so they don't have a lip that sticks out around the bottom edge of the frunk; it replaces that OEM plastic tray entirely, and it doesn't reduce the ground clearance or approach angle at all! And it's clear from the marks on the underside of mine that it does take the occasional hit - hits that would've destroyed the OEM plastic tray and probably broken the bottom of the frunk box as well!!
Btw, you really DON'T want to go 'raising' the front suspension on these RT's too much either, as that messes with the caster, camber, and steering in ways that aren't kind to your tires &/or handling! Sure, you can improve/beef the front suspension up a little so that your Spyder maintains it's ride height better under load, but don't 'lift' it - not unless you do that with slightly larger rolling diameter tires or replacement 'A' arms that are cranked to keep your steering geometry aligned properly! Fitting slightly taller a/mkt tires (ie, anything
BUT Kenda &/or any of their clones - Kanines, Arachnids, or even the latest XTS or whatever stuff) all round does a whole lot of other really good stuff for your Spyder too; so to me, it only makes sense to fit better & slightly taller tires and one of Noboot's Alloy Skid plates! Works for me, and I doubt there's too many Spyders around that've done close to the same sort of miles on dirt & gravel roads that mine has.
