Any pictures of handle bar risers anyone?
Red Recluse
Does anyone have pictures of handle bar risers on their Spyder? On the ESI site it doesn't show them close up to tell what they really look like. On the KewlMetal site it looked like you couldn't see the gauges good for the ignition switch which looked like it stuck out real far.
ESI 3" Riser w/ BRP 1" riser:
picture.php
picture.php
PE 2466 sent you pictures of the best riser to use.
I, PE 548, used 4 inch on top of the BRP 1 inch on the 08 SM and 09 SE. You must get under there on the right side and clip the wire tie on the steering head to use the 4 inch. Helps us a lot because we don't have to lean very much. Please understand even though you cut that wire tie on the head the wire will be tight when you go to the extreme left steering position. Usually the only time I go all the way left or right is when moving around in the garage. / Ken krb1945
I have BRP's 1" plus the NMN 3" - this works well for me. They are a bit of a pain to install tho...
