Web Runner
General Class
KB5EZQ
73's
KB5EZQ
73's
I've got 2 of the same rig, FTM-10R, I got specifically for my bikes, I just haven't taken the time to mount them. I am trying to decide how and which antenna to mount. Around here most folks stay on 2 meter, so my antenna choices will primarily be for those frequencies, I've also got the bluetooth installed on one of them, so intercom won't be a problem, either. I'm thinking of running the main unit in the trunk, or saddlebag, and run the extension under the seat to the glove box with the head mounted inside, for security. Not sure whether I want to run it full time hot, or turned off with the ignition.
I couldn't have chosen a better callsign than the one the FCC assigned to me, being a retired Army medic, if you take the region number out of my call it becomes KILL U, KI4LLU, how cool is that, lol.
I'll be watching this thread to find out the antenna choices y'all come up with.
Doc
The only antenna that will work is something that is 1/2 wave for 2 meters because of no ground plane. I think mine is Diamond dual-band. Radio is mounted in the frunk on the right side rear wall. On my limited, its behind thr zipper on the frunk lining. Antenna ia mounted on the back left side where there wasa spot for a 2nd antenna, opposite the factory radio antenna. I used a stick on mount because of limited mounting options. I'll try and get some close-up photos and post them.
Cool thread. Well, they are assembling my RT today so I'll be another HAM on a spyder.
(Amateur Extra)
I like the pic of the install above - I have an ICOM 880 I may install like that as it's head unit
is separate. Although the new 2730 or 5100 look nice. I also have a couple 2300H's I could
use but they are an all in one unit so installation would need some room. On the plus side
for the 2300 is they have no fan.
Question: Has anyone ever installed an HF rig on their Spyder? I have a 7100 that I'll probably
end up installing in my diamond plate trailer (Main unit and probably a screwdriver antenna) and
have the head unit to put on picnic tables while camping. I'm wondering if anyone installed
a mobile HF all band/all mode unit directly on the spyder, what antenna they like, etc.
Dr Buck, how did you tap into the Spyder PTT button?
I'm a technician as well. KD7SII, down in AZ. I wonder how many Spyder riders on here are Ham's?
Sent from my DROID X2 using Tapatalk
