If those lights are anything like the lights going by the same make/model/description we get here in Oz, then you won't get a great deal of '
distance lighting' from those lights, certainly not anything that really '
fills the space between your low beams and high beams', as the light from them, while LED '
Bright', isn't likely to project much further than your Low Beam lights if at all, probably not even extending any further than the low mount Fog Lights you get over there that we get as a poor excuse for Low Beam headlights here in Oz, cos those Fog Lights are designed to have less penetration & therefore less light scatter in fog than your 'normal' Low Beam!! :lecturef_smilie:
The lights in your link are
Work Lights, designed to provide a fairly wide spread of short-range light, not a wide or even narrower beam with any 'distance penetrating' capability of any benefit beyond your Low Beams... You really want a
'Forward Lighting' Driving Light or a really good
Fog Light with a wide but 'cut-off' beam mounted up high to give you the distance you need beyond your Low Beam light spread - maybe even mount those Fogs off the little 'plastic' OEM 'winglets' that are just underneath the bottom outer corners of the Windscreen on the 2010-2019 RT's
hyea: You wouldn't be the first person to have done that, and I don't think that any of us who have done so have had any issues with using the 'plastic' as a base/mounting position for a lightweight
Driving Light?!
