antifreeze leaking
spydee64
we are just getting the bike up and running and its leaking antifreeze we put more in and now its coming out the overflow any ideas? thanks
If you are absolutely sure it is coming out the overflow, and not just following the hose down, it is likely either that the cap was not tightened to the second detent, the cap is bad, or the coolant tank has been overfilled. There are some other obscure causes, like a blocked coolant hose, but those are quite uncommon.
Definitely check your cap. It is not uncommon for it not to be put all the way on even though it feels like it is, there is one more turn. Trust me, I have had this problem so I know that is how it happens.
:agree: For some reason the cap is a little tricky to fully tighten.:dontknow:
