Antenna Hole Cover for RT
bobgeorge
Hello,
I was never planning to use my radio...but then I broke off my antenna. Plus after that I lost that rubber cover.
Now I am just looking for something to cover up the hole.
Anyone have any recommendations?
Thank you in advance!
REPLACEMENT CAP
Hello,
....Like is on the other side is available, I think they come color matched.......They just pop in..............Mike :thumbup:
I checked with a local dealer. The ordered me a cover like for the other side...but it said "LS". It didn't fit because the grooves wouldn't match up. The tech looked in the computer and couldn't find a "RS" cover :sour:
The right side is available in limited colors, you will need to paint it to match body color.
I have one installed where our FM antenna was removed since we run a hidden antenna and IPod.
The paint I show here is not a great match, you can see it is off, but closer than the oem silver gray. At some point I will but some real paint and spray it.
Hope it helped
PK
COVER
I see Paul already chimed in on this.......I thought I had read about what He had done and that's why I made my suggestion to you.. So I think you have an " ISSUE " with your parts person at the dealer ship................Have you tried to re-turn it ? ? ?...........Did they take it back ? ? ?...............................and if not What did you pay for IT ? ? ?................Mike :thumbup:
Hope it helped
PK
What dealer can order the right side? I've went to two dealers and they said they cannot order a right side cover.
If you take the photo that I posted of the bag that has the part number on it. Show them that part number and ask them to order it.
Any Can Am Spyder dealer should be able to obtain the part.
PK
PK
I will try that. Thanks!
Antenna Hole Cover
I removed the OEM antenna off my 2012 RT-S about a year back and replaced it with an $18 hidden antenna off eBay.
At that time the only "plug" available for the right side hole is a plug for a 2010 RT in Magnesium color, as that was the only year/model/color that came without a radio, therefore no antenna on the right side.
Unless yours is that color, it will have to be repainted to match.
Mike in KY
