cyclerider
I have a 2016 F3 T and recently installed a Madstad windshield and bracket. At 70 mph the shield shakes and flaps violently as if it is going to fly apart and come off. The dash, handlebars and mirrors are shaking noticeably different after installing the Madstad. I have had no issues when I have used Madstad brackets with different shields on other bikes. No matter how I angle it or what height it is adjusted to it shakes and vibrates badly. The stock shield has those two vents cut out at the bottom. I wonder if that or those flimsy brackets, or both are the problem. Has anyone else experienced this? Also, will the F4 shield bolt right up to the Madstad bracket? If it does will the F4 shield vibrate as well? Thanks!
