deadboltdon
I have been spending the last few days researching tires for the front of my 2011 RSS. Maybe a new rear (replaced once and not liking the Toyo Proxxess 4.)
The factory size 165/65/r14. I have noticed quite a few have gone to the 185/60/14 this opens up a lot more options.
I have horrible shaking (front) at anything over 80-90 KM/H I have used the ride on liquid balancing in the rear and loved the difference. Added it to the fronts last year and helped slightly but not enough. While I had the shop add the ride on they showed me my sidewalls were cracking. This year I plan on more highway riding so need to get this fixed, for safety and piece of mind.
Being in Canada I have limited access to some of the brands you guys have.
My question is, will a "summer" tire be best suited on the spyder? I can only ride in summer anyway in Winnipeg MB. CA. May till Sept. early November sometimes.:dontknow:
From what I think I know, a all/no season tire will be louder on the highway. Same with "Winter tires in summer".
I am looking at 2 options IF summer is the way to go.
Weastlake SA57 -$82 CAN each.
https://www.partsengine.ca/44030-vp-west-lake-407.aspx
or Zeta ZTR20 - $70 CAN each
https://www.partsengine.ca/ZT1856014N-vp-zeta-tires-484.aspx
The Zeta has a matching 205-60-15 that could work on the rear if I decide to get all my tires from this one guy IN Canada.
I have read good things about the Vee Rubber on here.
I have found a Vee Rubber Arachnid for the rear in stock size. That can ship to me. And because it it "listed" as a "MOTORCYCLE TIRE" It should come duty exempt across the border.
In the end ANYTHING is better than the factory Kendas!
What is sickening is the 2 front tires are cheaper than the alignment will cost! And the shop I HAVE to deal with took 2 days to get that cost for me AFTER I called them back......... May drive to the next province to get this done, this shop feels like they don't care about the spyders that much any more.
For the guys that did the 185/60/14 wider tire in the front did you have any issues getting a alignment done? Or Did you get one done and everything is still same as before tire swap?
