wyliec
it's not as good as Rogue's question.
I have a Keen Kanteen water bottle which I use when working out. It has a gasket on the screw in top. What I have noticed is when sitting upright for awhile, the top/cap is difficult to remove. Then, I have to turn the bottle over and upright a number of times, and then I can get the top/cap off. Is there something that I should do with the gasket? I have removed the gasket to see what happens, and the bottle leaks. The bottle is probably only a month or two old, and the gasket is fine. I purchased another brand water bottle, and it doesn't require a gasket, and no problem. I'm assuming the new bottle has a more finished surface where the top meets the bottle.
Like I said, this isn't as interesting as Rogue's question.
Rogue,
Do you remember when you were relatively new on here, and you asked a question about exercising? I'm just checking your memory. I did enjoy that question also.
Rogue,
