Another Newbee - some general questions
Taraspyder
I just went from being up on 2 for the last 47 years to being on 3 as of last Friday. I bought a very low mileage 2011 RT-S, SE5. I rode it back from Sanford FL to home (Hickory NC) on Saturday and really like it. Please humor me by answering a few questions you all have probably heard 100 times.
I definitely want an anti-roll bar. Is BajaRon the best or is there a better one?
I am going to need to run power to the handlebar area for GPS, radar detector, and Gerbing. I had a fuse block on my last two wheeler and assume I should use one for this application too. Any one better than another?
What about mounts for all this stuff? I have used RAM mounts in the past, are they preferred for my application or is there a better way?
Thanks for your help.
Congrats on the new machine! Remember to upshift at 4500 or higher rpms. The engine is designed to run at high rpms. The power starts to come on at 4500 rpms and higher. The shifts will be quicker and smoother at higher rpms. The Bajaron sway bar will help greatly.
As far as i know ............................. the Baja Ron Bar is the only after market bar for the Spyder. And be sure to check out Spyderpops on the home page for Bump skid, grills etc, etc
TricLED & WireDux for Lights
JThornton for mounts
Keep those front tires at the same pressure to improve handling
Don't put your feet down at red lights
Don't look for the Kickstand (they are optional :roflblack:)
Welcome aboard
Cruzr Joe
Joe,
I heard that the kickstand will once again be standard on the 2016 Limited... :thumbup:
It was removed when they "de-contented" the RT line-up, in 1998. ;)
Here is what I did and I found that the complete X-grip is cheapest at Walmart, you buy on-line and pick up at a store. I am not using the suction cup.
:welcome: & :congrats: on your new toy.Since your Spyder is used just make sure you do not have Ron's sway bar already.
Now THIS is what I call a great forum!
Thanks for the info guys and gals! I think I found a home here. One more thing: I've been out in the cold garage looking everywhere for that kickstand. Do you think mine is electric and retractable???
I would check your manual under "disappearing Parts Configuration". :roflblack::roflblack:
Welcome to the world of Zanies, Are you going to attend Spyderfest this year??
Cruzr Joe
Spyderfest
Cruzr Joe
I am sure gonna try - I was not aware of Spyderfest but what I see online looks great.
Welcome..!! Welcome..!!
looks like they've got you covered...so welcome to the spyder world and this awesome site. Feel free to ask anything you have doubts on...:2thumbs::clap:
POWER
as for having POWER by the handlebars... here is my solution for my '09 RS...
2 12V plugs, purchased from CYCLE GEAR, $9.95 each... ran them directly to the battery...
i also have 1 mounted in the frunk...
they are all HOT at all times... i plug my Battery Tender into one of the ports on the dash as you
can see by the 4th picture...
hope this helps, good luck and welcome to the group...
Dan P
Easley, SC
SPYD3R
Another question...
Stormtrouper suggested that I check and see if the previous owner already installed a BajaRon swaybar. I crawled under today and there is a swaybar, black with the plastic ends. One of the pix I saw depicted the BajaRon bar as orange. Did the factory put a bar on the RT or could I have a BajaRon??? How can I be sure?
Thanks!!!
Welcome and enjoy.
The RAM mounts work well on the Spyder. There are four 7 mm bolts in the center of your handle bars that are the mounts. Two of these make excellent places to position RAM mounts. You will need to remove the bolts and replace them with ones that are about 1/2 to 3/4" longer so that you can add RAM mounts. As you can see from the photo I added mounts for my cup holder and for my I phone. You won't find longer bolts in a 7 mm size (only Can Am uses 7 mm anyway) so you will have to go with 8 mm but as long as the thread is the same you are good to go.
You will also need a small chrome spacer to hold the RAM mount in place between the bars and the mount. I used the two upper bolts in my application.
